Reflectix heat shield
dodge71demon
Indiana
I am considering using Reflectix reflective insulation on my Project Scamp.Menards has it on sale at quite a savings.Has any body used it on their car interior to reduce heat?Does it help any as a sound berrier which I'm sure it will at least a little but how much?Please do not suggest any other product I'm just looking for info on Reflectix or maybe using this in combination with another inexpensive product.
Shoot yeah man!!
You want to put some kind of sound deadener down first then use the Reflectix or it. The Reflectix is not a good sound deadener. I did the floor board and doors like previously mentioned and the car is much cooler now. When you shut the door is sounds quite and solid. good luck
Shoot yeah man!!
What sound deadener?I'm thinking of using a smooth rubberized undercoating first then the reflectix?????????????
I use this stuff alot when insulating telecomm equipment. It is not a very good insulator for heat but it yields good insulation properties for its thickness. It will be good to glue it down to force it to mold shape to your area. It is a pain to keep it in place unless it is glued down. What I would suggest rather than undercoat for sound deadening is just buy regular carpet pad from lowes or that mernerds store and put that down to your metal first (inside the car), then over that run the thermal barrier, glue thermal barrier to the carpet pad. Several advantages. You can remove the thermal and sound dampening assembly to work on your floor board. The heavier and more absorbent the material which contacts the metal, the less sound will come thru. Plus with that pad between the thermal barrier will be a big thermal barrier enhancement.
I am debating just gettting some good quality water proof carpet pad for my floor and using the alum bubble wrap stuff too! Mostly because the combo would be an excellent sound and thermal barrier. Until it caught on fire. Then it would create noxious gasses.
Oh, I made a headliner out of it for my ranger, glued it to the existing backboard. Painted it black. Looks like the inside of the space shuttle.
I'll share my experience's with you. This product is basically bubble wrap with foil on both sides. When the bubbles are broken as on floor installations the effectiveness is lost plus any moisture has a place to pocket because of all the voids. A product we use is designed differently as there are no voids to trap moisture and no bubbles to break down as it's a closed cell product that lends itself well to auto applications.
We install it with 3M General Trim Adhesive. We've used it on doors, floors, roofs and firewalls and found it to be an excellent product that is very reasonably priced. My son installs high end sound systems and prefers this product over several of the other sound deadners out there. I'm only sharing my experiences here nothing else. See what you think. EZ Cool Insulation Co. www.ezcool.us Dan
This http://www.dynamat.com/
or
this http://waterprooftape.net/store/B00...S433-SELF-ADHESIVE-WATERPROOF-FLASHING-4"X33'
You can get the COFAIR at Lowes in the roofing section. Its not as thick as dynamat but you can put down two layers of it and it is the same. You will save some money while get same benefit. This is what I used. I used it on my doors (inside door panel area) and they shut solid!!! You don't HAVE to use two layers if you don't want too. On the doors make sure you tuck the Reflectix in the bottom grove of the door!! If not you will have water running inside the car. This is very important. Its purpose as well as dynamat is to take the "drum" effect out of metal thus called sound deadener. Its really according how much money you want to invest. I work at auto glass shop and have noticed on a few classic cars that they put a sheet of deadner on the skin of the door(inside the door) I didn't do this to mine but I bet it will make a difference. I have noticed newer cars are already have it on their door skins.
Like mentioned above it is best to glue the Reflectix down to the sound deadener as it will want to move around.
