70Duster440
Started tearing my custom dash and column apart to fully expose the harness and also replace the ignition switch.
This is a little off topic but I thought I'd show the steering shaft/bearing removal tool I threw together. It mimics the factory tool.
In order to get to the ignition switch you have to remove the upper section of the column. Some people get super lucky wiggling it off. Others are more barbaric and use screwdrivers to pry it off. I have a new upper bearing in there so there was no wiggling and prying it off was totally out of the question.
I took an extra turn signal switch retainer and welded a tube, washer, and nut to it. Section came off easy as pie. Once it's off you remove the sleeve from the lock plate hub, the snap ring, drive the roll pin out, and slide the lock plate off. The switch is easily accessible now.
