relay amps?
71dustar
Fountain Hills, Az
What amperage relay should i use for push button start, ignition toggle switch, and then misc (lights, fans, etc.)
do i need to use a 30 amp circuit breaker also when using a relay?
Yes.. Example the relay head light kit I used from Painless came with a circuit breaker. I didn't pay attention to what amp it was because I just mounted it and just though it would be the right amperage. I'll look tomorrow when I'm back out in the shop if I don't for get.
when Im wiring,
I run 30A for Low Beam, 50A for High Beam and I use the Relays with Inbult Fuses.
For the Push Start ignition, I would use a 60A as a precaution.
