Installed 4 pin HEI module on inner fender and moved coil up on top of inner fender too, about 4 months. Left old Mopar coil and ignition in place, disconnected, just in case the HEI module fries. Already happened once (my fault) and saved my rear. Got new Aurora plug wires and coil wire is too short to reach new coil. Is it ok to move it down to the inner fender or will that be too hot? Does upside down or right side up make a difference? Any and all input and advice are appreciated greatly!
