Remove decals from lexan
wirenut
Anybody have a prescribed method for removing decals from lexan windows without scratching, clouding etc? The decal comes off easy enough, but the remaining adhesive not so easy.
G
Try cooking oil or baby oil and a cheap hair dryer with a soft cotton cloth (ie, baby diaper). That will usually loosen the adhesive without scratches. After that, you need a good cleaner to remove the oil. JMO.
Wd40. Not sure if it will cloud the lexan might try a small area.
Denatured alcohol-soaked rag placed on the decal and allowed to sit and soak to soften the decal...WD40 to remove the adhesive residue.
i would try using the heat from the sun first. if that doesn't work a hair blower, this will not warp the lexan. if the decal is cracked from being installed awhile back do what slantsixdan mentioned
They make a product called Plexis available at motorcycle shops for bike windshields for cleaning without scratching using a microfiber cloth. Works good for final clean up.
So a little heat from a hair drier, then peeled them of and then Dans denatured alcohol dabbed on the glue repeatedly, and carfull mop up with another paper towel with more alcohol.
Thanks Guys
