i am going to be removing fenders from a parts car tomorrow. can any of you tell me the process of removing a fender off the 65 dart? does the bumper need to come off? where are all of the bolts located? About how much time will it take to remove two fenders? Reason for these questions is i wont have much time to do this. thanks guys
Step 1: take off the headlight and remove wiring. You need one Phillip screwdriver.
Step 2: remove the 1/2' head bolts on the radiator support, two bolts on each side.
Step 3: remove the front inner splash shield, four 7/16' bolt and the four bolts that holds the fender to the front valence.
Step 4: remove the middle bolt that hold the rear splash shield against the fender, one 1/2' bolt and the rear lower bolt, 1/2' bolt that hold the fender to the rocker moulding.
Step 5: remove the rear upper nut. 1/2' nut that holds the fender to the cowl.
Step 6 remove the four bolts 1/2' bolts on the inside toward the engine compartment.
Step 7: remove the front upper nut, 1/2' nut under the hood bumper.
Step 8: remove the fender.
You can make the two fenders on 90 minutes without alot of rust. WD 40 makes the bolts easier to loose.
Good luck!
