Removing glued on carpet, any tips?
340sFastback
Maryland
Any tips on removing the carpet that is glued onto these interior panels? I glued it on back in the '80s with some type of spray glue and its crazy difficult to pull off. Any tips to get it off?
The spray glue you used was probably banned for containing all the chemicals that caused all the cancer and death.
So i'd bet its good ****. and it wont be coming off:poke:
With that being said, some of the newer spray glues don't like water. stuff just peels off of it. maybe try that????
I've had luck with Automotive Goo-Gone, make sure it's the Automotive variant.
Removes undercoat too.
Also, it's easier to remove things with like things, for example I've used oil to remove a petroleum based glue, whereas using hot water and soap was useless.
The Heat gun may very well work. I guess you would not care if the carpet got damaged.
You could also try steam. You might be able to rent a steam cleaning machine.
