Pirate duster
What is the best way to remove an intake without damaging it. Aluminum type. Thanks
patience and a careful prying under the front and rear where it seals to the block, unless you have a hoist.
Has always worked for me...1st remove bolts.... 2nd remove intake... 3rd drink beer...
X2 on the use of a hoist. Put tension on the intake with the hoist and tap the intake with a dead blow.
alrighty. ill use my cherry picker and plate maybe with dead blow. i am not using the screwdriver method. brand new performer air gap is what im taking off. i drop the damn carb stud bolt down in there and couldnt get it with a magnet. sucks too. i just put it on a couple weeks ago. hopefully no more butter fingers. lol
Put a hammer shaft down into the plenum and rock it back and forth. Off just like that.
