Removing the dashboard switches - dart 65
Dart 65 /6 170
Denmark
i am currently trying to remove the dashboard from my dart 65 but i can seem to get the switches out, wipers and ligth switches
The wiper knob is held in place by a set screw. If you rotate the knob you should see it. To remove the headlight knob reach under the dash and find the switch. There is a button on the opposite side as the wiring plug. Depress the button which will release the knob along with the built-in shaft. You will then see on the front this fastener with evenly spaced little tangs. There is a tool that’s sold on eVay to remove this faster et. Or use a small screwdriver and carefully tap it to remove both the light and wiper switch. Good luck and welcome to FABO!
THANKS :D
Pull the headlight stem full on before pressing stem release button. Tapered end of stem should guide it past the latch so no need to push button when reinserting.
