Feb 16, 2015 #1 Bud27 Well-Known Member Joined Dec 26, 2014 Messages 156 Reaction score 10 Location West LA How do I remove the upper control arm from a body. So far,removed shock, relieved torsion bar.
Feb 16, 2015 #2 Ben Drinkin Hey bartender! Joined Sep 15, 2013 Messages 20,397 Reaction score 16,815 Location Caribbean coast Pop the upper ball joint loose (pickle fork and bfh) and then remove the upper control arm cam bolts (lots of penetrant and a few cuss words help)..
Feb 16, 2015 #3 Dustert73 Stripping bolts since ‘10 Joined Dec 22, 2014 Messages 884 Reaction score 171 Location Ohio Ben Drinkin said: Pop the upper ball joint loose (pickle fork and bfh) and then remove the upper control arm cam bolts (lots of penetrant and a few cuss words help).. Click to expand... X2, when you remove the camber bolts it makes it easier to get something you can put behind the arm to pry it out as well.
Feb 16, 2015 #4 Bud27 Well-Known Member Joined Dec 26, 2014 Messages 156 Reaction score 10 Location West LA The BFH DID THE TRICK with help of big fre@king screw driver . My pickle didn't have enough girth . Lol Thanks for the quick replies .
