Replacement window guide channel felt.
C2ndLTpigeon
Mopar or no Car!
Indio California
I'm looking to see if anybody knows where I can get replacement window Channel felt that will fit our cars mine specifically is a 1973 Valiant. I would like to find something to replace this crappy rubber that the previous owner put on both doors.
So is this the stuff that attaches to the leading edge of the door glass? Then there are small metal pins and plastic pieces that hold it on? Or is this something else?
Yea from what I can see that kit does not look like it would be used in my application, nowhere do I see those pieces. The area I showed on the picture with no seal in it is a empty channel, no indication of screw holes ore those plastic pieces. The stripping I found makes more sense as the channel has a small lip and the seal has those to edges on the out side. looks like the stripping would just push fit in.
