hey guys i have a bad whine when i push the clutch in and hard to locate first gear. I think it is the release bearing. is there any tricks to replace the bearing Or just start wrenching.. thanks
I will take a look for any bent rods. But to change the TO i have to pull the box and bell housing correct?
You don't need to pull the bell unless you are changing the clutch on a scatterproof / steel bell and even then, on factory bell, the clutch will come out the bottom
Hey guys got the box out last night. the TO bearing is shot. one thing a found is that the input shaft has some play. is this normal. Is there a way to check the pilot without removing it? i did notice the tranny went into gear nice without the engine running before i started the job. thanks
I'll chip in with my 2 cents.
First thing i would do is get a factory service manual.
Whats the aproxx canadian price of a clutch and p plate kit? Say from MP thanks
To check the pilot bushing, i would shine a skinny little flashlight at the hole and see if it's obviously egged out. Then put your finger in there and see if there's any big filings in the cavity past it in the crank. (beware, the filings are sharp!) It's not that expensive to replace it anyway.
The input bearing should have some slop in it, that's normal.
If the clutch release bearing was shot, it makes me wonder about the rest of the parts in there especially the pressure plate fingers. If it's hard to put into gear, either the clutch is badly out of adjustment, binding somewhere, or the linkage is binding/badly out of adjustment. (Or a dry and dragging pilot bearing/bushing) The pressure plate springs might be very weak too.
Was the clutch engaging smoothly, or did it chatter?
Did it bite hard if you tried to do a burn out or starting out, or did it slip a little?
I think that you could use a complete clutch replacement really.
I would bet the disc, pressure plate, throw out bearing, and bushing are old and tired. The flywheel is probably glazed and worn and will need resurfacing.
Check the bushings and clutch linkage for slop.
If you want to change the throw out bearing and hope for the best, there's no real harm in that, just make sure you have a minimum of 1/2'' freeplay at the clutch pedal and don't ride the clutch anymore if that's what you were doing.
I think a full clutch job is in your future though.
I hope this helps.......
Tom.
Any of you guys running a Mcleod clutch. They seem to have a decent kit for a decent price. thanks
