Replacing wheelhouses
dart6
New Zealand
I have a 72 Scamp with rusted inner and outer wheelhouses. I'm assuming it would be quite an ordeal to replace those. If i got someone to minitub it would that do away with the wheelhouses and make the job alot easier?
Do the outers first and use the inner to locate the outer. Sheet metal screw the outer in place then remove inner. After everything is fitted then you can start welding in. It will be much harder to do if your trying to save the quarter panel. Typically you would be replacing the quarter at the same time since its probably rotten too. But anyway, I like to use original undisturbed metal to locate new metal anytime possible.
I dont think mini tub would make the job any easier. It will require fabrication which could make the job more difficult than just a straight up replacement.
