pishta
I know I'm right....
Heli's are almost a given in AL intakes. Especially the threads that get cycled, ie stat housings. Carb studs not so much as they dont get removed all that often. Stud the stat on still good threads and be done with it.
thread inserts are huge. I doubt they would have the room on a poly, as the drill is a .488 for this.
Helicoil would be the smallest OD repair or drill and tap for next oversize....(gasp) metric!
I used these for a LA pump housing on the bottom 2 holes from the oil pan. They worked great but the initial hole is huge.
What size drill for a 5/16 coil?
What size for a 3/8 tap?
