Re. ETA note...Here is the old hose that came off of it.lots of great suggestions above and i'll share the sentiment of keeping it factory. the factory "bubble top" radiator and shroud with a clutch fan is a tough combo to beat.
i understand if you don't wanna splash the cash for a new waterpump, but the flow cooler unit is a very nice piece and well worth the loot.
get a *good* t-stat, not some parts store junk or something labeled "race" or some such nonsense.
i've run that set up for the past 25+ years and it'll pound the pavement at 100mph thru texas in august and not break a sweat; and sit idling in LA traffic on a 110* day just cool as a cucumber.
ETA: you're going to need to lose that adapter you have on the bypass coming out of the pump. it's way too tall and you won't make the turn going into the manifold without kinking it.
Good catch on that bypass hose barb. I have no idea why the PO did that. I'll fix it. Thanks.lots of great suggestions above and i'll share the sentiment of keeping it factory. the factory "bubble top" radiator and shroud with a clutch fan is a tough combo to beat.
I know this was posted back in January, but I have to ask if this one is the one I need for the 1974 360 in my 67 Barracuda? I'm about to pull stuff off the front of the motor to put in a better cam and that would be a good time to replace the thermostat. I've looked at several vendors and cannot confirm it will fit an early LA motor.The Stewart Components stats are high flow & perfect for what the engines need. I've seen other "high flow" stats that were anything but.
Why is That? What's the difference?Murray is good. 2747 is much easier to install
I ended up having the original radiator recored. Don Hart Radiator in Waller, Texas, did a great job. They knocked out the dents in the top and bottom tanks, recored and painted.
View attachment 1716367138View attachment 1716367137
My experience with heater cores is that they are very inconsistent in dimension and configuration. I ended up buying one from Layson's that turned out to work pretty well. I had a little trouble with the orientation of the copper inlet/outlet nipples. To be honest, Rick warned me that I might have to manipulate the nipples a little to make everything fit. How true that was. I ended up putting a small kink in one of them by the time I got everything stuffed back into the heater box. I'm glad to have that episode behind me.That's not bad, don't laugh, I had $400. in a quality heater core.
