Lookin at a set of RHS LAX heads for a possible Mopar project I may do. I know nothing about. What do I need to know and or look out for? Thanks.
little story with these and a comp keeper.....
Mopar RHS Indy Cylinder Heads Dodge Plymouth Small Block 318, 340, 360 LA Heads
I myself think a good set of 360 heads (ones that didn't need valve guides etc etc) that were home ported and milled would fill the need for most applications, especially if 2.02's were installed with a good performance valve job.
IT'S NOT A RACE HEAD! It was made to be a stock replacement head. The head flows better OOTB than the factory iron heads. You can force it to make some real horsepower. The first time I got my hands on one was at the 2009 Amsoil/Mopar Muscle Magazine Engine Challenge. Both Cody and I thought, "Why did they make a stupid intake port like that?" There was a big boss cast into the port roof to support the Magnum rocker stud. And yes the boss is in both the LA and Magnum heads because they are the exact same castings (or they were in 2010). The exhaust port is far superior to the factory Mopar castings. When we tried back in 2010 we got 296 cfm intake and 286 cfm exhaust @ .600" lift. But it isn't too hard to get 236 cfm exhaust, which is 100 cfm more than the stock Mopar factory iron head. We've got a set of fairly exotic rocker arm LAX style RHS heads here that flow 264 @ .500" and 280 @ .600" with a 1.94" intake. We are going to put in a 2.055 intake, reassemble the heads and look for a good small block to put the heads on for some dyno testing.
Who is claiming it's a race head? I didn't see where that was written. It is what it is. A replacement head. With a crap combustion chamber.
Oh look, it's yellow rose disagreeing with industry experts. Again.
I'm sorry that you took it personal. Try not to be so sensitive, everything I write isn't about you. I was replying to the thread in general and giving my opinion on the head. You have some good ideas Rose and some opinions that I really do agree with. Just.......not always.....
Six years ago man, it's hard to remember. They are up in boxes on a dusty shelf and I can't remember exactly how the flow development went. We used the LAX head and put Chevy stud mounted rockers on it. Did we leave some of the boss in there? I think so because we got so far and there didn't seem to be any more flow gain. But again, these were only using a 1.940 intake because they were going on a big bore 292?/273. We have a LAX flowing over 300 cfm but it is in a box on the closet floor back at the house. Been there unopened since 2010.So did you find removing/porting the head to eliminate the support from the intake port since it's just there to support the magnum rocker studs made much of a difference in port flow?
Not sure what you're building RRR, but if it's a milder package I'd look at the EQ Magnums. MUCH lighter, similar out of the box performance, and a lot cheaper. Both come as bare castings - so rocker geometry may vary depending on if the shop does a valve job or not.
As was said - magnum based heads have issues with lift. So mild cams they works well. Going larger means more dilligence, or a different head.
Thanks for adding to the discussion. So you disagree with me? Who cares? I call junk what it is. Funny thing is, when a guy buys junk, he wants his buddies and everyone he can influence to buy junk so he don't look the fool.
I have spent hours with Dave Hughes in discussions on combustion chambers. We agreed to disagree. I have my understanding of combustion chamber geometry, how a piston at TDC completes it and how the valve job is dictated by it.
Since you probably can't address any of these, I'll say it again, I think that chamber is junk. Most like it because they think it makes compression more easily. Maybe so, but the compromises in geometry are more than I want to deal with. Look at a W-5 chamber. If you are not willing to think outside the box just on the valve job, a W-2 will beat it up. Which, ironically is what happened when the head was first released. Thankfully, I ran into a guy running Comp and warned me of the pitfalls. BTW, he was a record holding builder and was involved in the development of the W-7 head.
So have your pet theories and love affairs with GM like crap. I have some stud mounted rockers for sale.
Good gawd.
That goes both ways. You CAPPED it, not me. Was just trying to clarify because I thought I missed something.
Would you mind explaining your rationale on that? No sarcasm I'm honestly curious.
Good gawd.
Can you give more details on your combo. Intake,compression , solid roller ? ThanksI like mine. 500 HP from a real basic 416 which is 1.2hp/cube. Not bad for an old-school, iron headed small block with a FT cam. Torque is unbelievable in this thing, does not go under 430 ft lbs. between 3,800 - 5,800 rpm. I will be honest, I thought it would make a little more, like 525 but I made some choices elsewhere that had an effect on the overall HP so it is what it is. 500 hp is nothing to sneeze at though, should get me where I want to be with my car.
IMM CNC ported RHS heads, cam spec'd by Brian, 251/259 @ .50" solid FT with Hughes 1.6 rockers which comes out to just under .6" lift. Mine are cut for 2.02 valves.
Like said above, good rocker geometry, no shims needed. I did the whole ink on the valve tip thing too, they were dead nuts.
I didn't think these heads were any heavier than your standard factory iron casting. I never weighed them but my old W2s seemed way heavier. I believe they have thicker deck surfaces and wider valve cover rails if that means anything to ya.
The one issue I had was with the dowel holes. Took a little massaging and a couple whacks with a dead blow hammer to get them to seat all the way but it wasn't a huge deal.
Decent pieces for the money. Of course there are better heads out there but the price reflects the difference. These would be a good choice for anything under 600 hp. If you are looking to make more power, it would be best to look elsewhere. 562 HP from these is making some power.
Didn't think these were even being made any more but I could be wrong. I got mine several years back.
