Having a weird thing happening recently. I installed a Sunpro voltmeter a couple of months ago and things have been running well. Since I bypassed my original ignition and installed the HEI ignition module setup, she's been getting a good 13.5v at idle and 14.5 volts at rpms higher than 700 rpm. For the past couple of weeks, I've noticed a "rhythmic pulsing" of the voltmeter ranging between 13.5 and 14.5 volts at idle. Regular and consistent, up and down, up and down, up and down, in time with the revolutions of the engine. About every 1 second, so about 10 revolutions of the engine at 600 rpm, it'll drop down to 13.5 and then back up to 14.5. I can hear the engine idling accordingly and I even have an annoying vibration in my dash somewhere that keeps time with it as well. I know my P/S pump is leaking and occasionally whines and you can hear the whine keeping time with the voltmeter and the rattle in the dash. Could the P/S pump be dragging on the engine causing a pulsing of the alternator and affecting the revolutions of the alternator pulley causing the change in voltage. Or would some load on the voltage be causing the engine to revolve in that manner? The higher the rpm, the faster the rhythm of the voltmeter needle until I reach around 1500-2000 rpm then I guess the engine is turning faster than the pulsing and she holds a constant 14.5v. Before I start throwing $$ and parts at it, anybody experience this type of situation before?
