Seems like something is slipping
I don't think it's the transmission because it shifts nice and firm and nothing smells burnt.Seems like something is slipping
The first description points to a 2bbl carb, and depending on your speed/rpm at the moment you floored it could be considered normal.Ok my car doesn't have positive if only one wheel turns when it's jacked up, right? In that case I did two turns of the wheel and ended up with 2 3/4 turns of the driveshaft. Making it a 2.76. I've used a GPS to measure my speed and it's 3000 Rpm at 65. Now without all the computer stuff to calibrate my tach, my ear tells me it's turning a lot of rpm, not 2500. So I'm really thinking my torque converter really may be losing that much. When I punch it the rpms will go way up and stay there (about 2600) until I hit a certain speed and then they'll climb with the mph. Also at 65 if I punch it the rpms will climb a bit to say 3300 then go up with mph.
Do you think when the local shop rebuilt my torque converter they screwed it up?
318 has a 4bbl and cam. Some of these numbers are average. If I floor it the rpms "stall" higher before it picks up and goes. My gut is telling me the torque converter because it shifts hard and doesn't feel like it's slipping. The torque converter feels like it's "loose"...The first description points to a 2bbl carb, and depending on your speed/rpm at the moment you floored it could be considered normal.
If the TC jumps to 3300 from 3000 that is about 10% slip and could also be considered normal.
Therefore, I would get a second opinion on either the tach or the speedO. Either the trans is slipping or One of them is a liar. And I really doubt your trans is slipping; Cuz your TC is right at 10%. This might be a little high, but you can't get to 3000 from 2461 with that TC alone,cuz this is a 22% slippage factor.So that would put the direct clutch at 12% slippage. Transmissions,don't slip 12% and then suddenly stop slipping, at that 12%.
So I'm sticking to a liar in the hen-house.
Here is your speed to rpm formula.
(65mphx1056conversion factor x2.76gear)/ 24.5tire height x3.1416 converts to tire roll-out =2461rpm at Zero-slip.
Depending on the power the engine makes and the drag on the chassis, Your actual observed rpm could be a few percent either way from that. I estimate from 2400 to 2580. Unless your engine is in a really,really,poor state of tune, then a maximum of 2700.
That's my best guess.
You're confusing me.318 has a 4bbl and cam. Some of these numbers are average. If I floor it the rpms "stall" higher before it picks up and goes. My gut is telling me the torque converter because it shifts hard and doesn't feel like it's slipping. The torque converter feels like it's "loose"...
It shifts into gear hard, not slipping, but while it's in gear it'll be a high rpm and stay there until the speed catches up to the rpm then the rpms will climb.You're confusing me.
"it shifts hard and doesn't feel like it's slipping. The torque converter feels like it's "loose........ which is it?
Well if it's a 4bbl and a cam, then something ain't right, about the combo.
Are you sure the secondaries are opening?It shifts into gear hard, not slipping, but while it's in gear it'll be a high rpm and stay there until the speed catches up to the rpm then the rpms will climb.
I need to work on the carburetor. I know I've got a blown power valve. Let me get things sorted with that and then I'll see what's up. This was supposed be an easy gear ratio question...lol.Are you sure the secondaries are opening?
What cam is in there and at what compression ratio?
From where I'm sitting, the only thing I see wrong is the tach.
I don't suppose your tach has one of those switchs on the back for matching it to the number of cylinders you have,eh? If it was set to 6cylinders instead of 8, the rpm offset at 2460 rpm could be very close to reading 3000.
Yeah it's funny howchit goes.....I need to work on the carburetor. I know I've got a blown power valve. Let me get things sorted with that and then I'll see what's up. This was supposed be an easy gear ratio question...lol.
Nice big fireball while setting timing and it's an old Holley without the check ball. Biggest I could find locally was a 6.5. Of that doesn't work I'll take a vacuum reading and get the appropriate size. Right now the idle screws are almost closed to make it run.Yeah it's funny howchit goes.....
How do you know the PV is blown.
If you swap it out, put a 10.5 in there.
The power valve didn't cause the fireball, me messing with the timing did. If I had to guess I would say it'd be a 8.5 PV but I'll have to see what the vacuum is and divide by two. I'll keep ya'll posted.Are you sure a leaking PV caused the fireball?
The same thing can happen when a pressure pulse comes up the intake manifold and back thru the carb, followed by fire from a late closing intake somewhere. The venturi don't care which way the air is moving thru it, to unload fuel.
I'm not saying the PV isn't blown, just that you gotta prove it. And again your idle vacuum has nothing to do with PV selection. That cam wants a 10.5 or something very close to it.
