jhdeval
Ok I am hearing a roaring when I take off from a stop. I have already replaced the front bearings and races both inside and outside. I think it may be coming from the rear end. I replaced the gear oil a while back with 90 weight gear oil.
I believe the roaring may be coming from the rear bearings. Any tips on how to pull the rear axles to have the bearings cut and pressed on? If I remove the rear brake drum should it just pull out? Do I need to drain the rear end again?
