So I just got my new heads for my 360, which are aluminum eddys, it says that I can't use stock rocker arms, which is what I was planning in doing. My camshaft is a comp 268 (268 duration and .477 lift, 280 and .480) I've read that with higher lift there is a possibility of punching a hole through the rocker arm. Is it correct to say that it would be recommended to get some adjustable ones? And I take it that push rod length would be different as well?
