Need some advice. I am putting together a 440 with eddy 84cc heads, Lunati solid roller cam 237-243 @ .050 .566 & .573 lift. The question I have is on roller or non roller tip rockers. With a non roller tip will there be an issue with the side loading on the valve stem. I understand the correct length push rods and the geometry needs to be correct for the set up. Primarily for street. Thanks in advance.
