S slx70 Well-Known Member Joined Jan 17, 2011 Messages 82 Reaction score 13 Location ohio Oct 18, 2013 #1 I installed new mopar performance hydraulic rocker arms over oem used shafts, when I primed the motor i noticed that oil was comming out of the end plugs on the shaft, is this normal?
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,297 Location Idaho Oct 18, 2013 #2 Uh, no..............photos?
Bad Sport HALF A BUBBLE OFF Staff member Legendary Member Joined Jun 12, 2010 Messages 44,805 Reaction score 34,728 Location The Wolverine State Oct 18, 2013 #3 Yeah, a pic would be good. Did you install them in the correct orientation?
M moper Well-Known Member Joined Dec 27, 2004 Messages 15,899 Reaction score 2,490 Location eastern CT Oct 18, 2013 #4 No. Shafts should be sealed. You could probably replace those caps tho.
