Rocker to Retainer with Pictures
Small Block Mopar Engine
  1. thomasfouraker
    thomasfouraker Well-Known Member
    119
    34
    Feb 2, 2020
    Jacksonville
    Local Time:
    5:33 PM
    Through my research I haven't found an objective spec on what it should be but more less "exercise the rocker arm throughout its throw and check for interference. Provide clearance and adjust as necessary". Seems a bit generalized.
    I am hoping to run these HS 1.7 on my Magnum Heads but I upgraded to a larger spring and retainer combo to work with the cam I have. It brings the arm pretty close as you can see. I know a Dremel could relieve that some if need be.
    Wasn't sure if there was a spec for reference or something anecdotal.
    Thanks!
  2. lilfontleroy
    lilfontleroy annoyinglilLeroy FABO Gold Member
    3,985
    3362
    Nov 20, 2017
    Intercourse
    Local Time:
    4:33 PM
    anecdotal ~ a miss is as good as a mile... and, if it ain't broke, don't fix it. But I see your point, that is close!
    • Agree Agree x 1
    • thomasfouraker
      119
      34
      Feb 2, 2020
      Jacksonville
      Local Time:
      5:33 PM
      Thanks for that reply! Its actually more the spring interfering than the retainer. My fear is that spring starts dancing around, plus heat expansion and then it begins to self clearance.
      It seems like I have about .018-.020 like it is. Hard to get a wide feeler in there.
    • lilfontleroy
      3,985
      3362
      Nov 20, 2017
      Intercourse
      Local Time:
      4:33 PM
      aka: tear itself up ~ enough said
      I really don't know what I would do if faced with this... at the very least I would contact HS and run it by them.
      • Agree Agree x 1
      • 4spdragtop
        4spdragtop CONGRATS NORTH AMERICA!
        31,814
        12350
        Aug 28, 2009
        Wasting time here
        Local Time:
        4:33 PM
        A slight touch of dremel like you said should do it but as for a spec???
        • Agree Agree x 1
        • tinman2
          tinman2 73 Dart 340 Sport FABO Gold Member
          176
          123
          Oct 20, 2014
          Conover, NC
          Local Time:
          5:33 PM
          If you do grind any clearances, be sure all the grinding marks run lengthwise with the rocker and NOT ACROSS. Then polish it back as smooth as possible. Hopefully you could use a Dremel ball file and just dimple it in the center (not all the way across) still keeping the rotation lengthwise.
          • Agree Agree x 2
          • Like Like x 1
          • thomasfouraker
            119
            34
            Feb 2, 2020
            Jacksonville
            Local Time:
            5:33 PM
            Any particular reason for this? Just out of curiosity.
          • tinman2
            176
            123
            Oct 20, 2014
            Conover, NC
            Local Time:
            5:33 PM
            Any cross direction scratches from grinding or sanding is like a crack starting. Think about a piece of wood, like a 2x4. Cut a groove in the surface across the middle of the board. Support both ends and stand on the middle. Guess where it will break. Take another 2x4 and cut a groove lengthwise. Do the experiment again.
            • Agree Agree x 2
            • thomasfouraker
              119
              34
              Feb 2, 2020
              Jacksonville
              Local Time:
              5:33 PM
              I figured it had to do with grain/strength. I appreciate that explanation it makes complete sense.
              • Like Like x 1
              • Garrett Ellison
                Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
                3,404
                2719
                Jan 1, 2018
                Southwest VA
                Local Time:
                5:33 PM
                I can't really tell from the angle at play, but what does the roller to valve tip contact area look like? The clearance should really be closer .050 with the stud rockers. Considering that the Magnum uses stud rockers, I would look into using a longer pushrod. Crower has a pile of various pushrods in their clearance items on their website for pennies on the dollar, you might could come up with some there.
                Clearance
              • toolmanmike
                toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                58,877
                45998
                Jan 18, 2006
                Iowa
                Local Time:
                4:33 PM
                I bet the springs will move around a bit as they cycle at 6000 r's. You don't need a lot of clearance but you will need some. I don't recall seeing a spec. (I used the wrong springs but with the right shim they work)
                • Like Like x 1
                • Garrett Ellison
                  3,404
                  2719
                  Jan 1, 2018
                  Southwest VA
                  Local Time:
                  5:33 PM
                  The Chevrolet people recommend .040 for their stud rockers. There are claims that longer pushrods will produce more power on the Dyno. In IMHO, that would more be a function of the rocker geometry needing help to begin with instead of “magic snake oil” happening.
                • thomasfouraker
                  119
                  34
                  Feb 2, 2020
                  Jacksonville
                  Local Time:
                  5:33 PM
                  I haven't set up my geometry yet but, have it "mocked up close" to where my rocker arm is 90 degrees at 1/2 the total cam lift. Its not an extreme cam, .316 so .506 with 1.6 and .537 with 1.7s.
                  I will know more about stem contact area once everything is mounted. I ordered a measuring pushrod that should let me dial in the right length for proper geometry and stem contact area.
                  • Like Like x 1
                  • Locomotion
                    Locomotion Well-Known Member
                    3,192
                    745
                    May 31, 2004
                    Florida
                    Local Time:
                    5:33 PM
                    For future consideration, one can look at beehive springs, if one can be found with similar specs as the recommended standard spring.
                    • Like Like x 2
                    • Agree Agree x 2
                    • Garrett Ellison
                      3,404
                      2719
                      Jan 1, 2018
                      Southwest VA
                      Local Time:
                      5:33 PM
                      Adding a little extra clearance with the aforementioned method with a dremel or die grinder would be okay. It wouldn't be the first set of Harland Sharp rockers that have been likewise modified for a little extra safety. Hopefully, you may find a little extra clearance when you finalize your geometry, too.
                    • yellow rose
                      yellow rose Overnight Sensation FABO Gold Member
                      28,507
                      24934
                      Jun 19, 2015
                      Central Washington
                      Local Time:
                      2:33 PM
                      Do NOT grind the rocker. Your springs aren’t big enough to warrant that, and it should NEVER be done.
                      Figure out why the geometry is off and fix that.
                      If you need help talk to Mike at B3racingengines.com and let him help you.
                      The rocker arm is no place to use a grinder.
                      • Thanks! Thanks! x 1
                      • thomasfouraker
                        119
                        34
                        Feb 2, 2020
                        Jacksonville
                        Local Time:
                        5:33 PM
                        Thanks for that reply. I think this is a result of having a part that was designed for a much smaller diameter spring/retainer combo and using it with a larger diameter spring and retainer.
                        I know there are rocker arms that have pushrod and retainer clearances machined into them depending on the application. I am definitely not going to spin the grinder unless no other reasonable option is available.
                        • Agree Agree x 1
                        • MOPAROFFICIAL
                          MOPAROFFICIAL Well-Known Member
                          7,906
                          7118
                          Jun 1, 2016
                          Beach
                          Local Time:
                          2:33 PM
                          Check full sweep clearance.
                          If your springs are dancing around, spinning or doing anything other than compressing and controlling the valves...you dont have enough spring.
                          • Agree Agree x 1
                          • thomasfouraker
                            119
                            34
                            Feb 2, 2020
                            Jacksonville
                            Local Time:
                            5:33 PM
                            I am running Hughes 1110 Spring and their retainer as well. Supposedly good to .550 lift with 120 on the seat at 1.65 installed height and should be seeing about 305-310 at my full lift. I don' anticipate problems but I do try to exercise my due diligence in preventing possible or potential problems. Videos like this don't make me feel warm and fuzzy about tight fits!
                            • Like Like x 1
                            • cudamark
                              cudamark FABO Gold Member FABO Gold Member
                              8,352
                              1109
                              Mar 14, 2009
                              San Diego
                              Local Time:
                              2:33 PM
                              I ran across that issue on a couple of engines using the 273 adjustable rockers. On one I was able to grind a real small amount off the cast iron rocker. The other, I had to use beehive springs with smaller retainers to get enough clearance. Neither engine had cam lift as high as 1/2" and neither was going to see 6 grand, so, I was not worried about a little grinding on the rocker. I've got over 75k on that one at this point with no problems.
                              • Like Like x 1
                              • MOPAROFFICIAL
                                7,906
                                7118
                                Jun 1, 2016
                                Beach
                                Local Time:
                                2:33 PM
                                Spring bounce.
                                Once they start spinning too.. power goes away and stuff starts braking.
                              • thomasfouraker
                                119
                                34
                                Feb 2, 2020
                                Jacksonville
                                Local Time:
                                5:33 PM
                                How much clearance would you be comfortable with? The clearance actually grows at greater lift for me.
                                Not sure if I could shim the pedestal some, I think that would provide some clearance as well.
                              • RustyRatRod
                                RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                                73,049
                                48537
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                5:33 PM
                                Exactly this^^^^^ If you grind something, you're doin it WRONG. The rocker shaft needs to be relocated. As mentioned, Mike at B3 can help make that happen.
                                • Like Like x 1
                                • Agree Agree x 1
                                • MOPAROFFICIAL
                                  7,906
                                  7118
                                  Jun 1, 2016
                                  Beach
                                  Local Time:
                                  2:33 PM
                                  The pic shows about .050 clearance, im guessing. Those rockers have a cup recess for the spring, so you probably have a little more than shown in the pic.
                                • yellow rose
                                  28,507
                                  24934
                                  Jun 19, 2015
                                  Central Washington
                                  Local Time:
                                  2:33 PM
                                  Unless your springs are 1.625 or bigger the notch isn’t too small, the geometry is wrong.
                                  • Like Like x 1
