Roller cam block - use flat tappet cam
sydcuda
ALICE SPRINGS, AUSTRALIA
I have a pre-magnum roller cam 360 block which I am using for a stroker build. I already have a new XE274H hydraulic flat tappet cam and don't want to invest the extra money in a roller cam as my coin would be better spent on a porting job on the Eddy heads. Quick question - can I use the flat tappet cam in the roller block without any issues or problems?
Cheers
yes..in fact went mopar started selling their 360 short blocks the 89-91 roller engines had .508 flat tappet hydraulic cams
Just got stage 3 Hughes ported Eddy Heads, now all I need is an engine!!!!
I understand why everyone loves the roller lifters but I still like a flat tappet cam for some uses. If the duration is under around 275, it actually opens the valves quicker than a roller...especially a flat tappet solid designed for a .904" lifter.
I'm strokin a 85 318 roller to 392 and I'll be using a flat tappet solid from Clay Smith Cams (custom). It's gonna be turbocharged so the duration numbers will be lower than an N/A motor so it will spool quick. In my case the flat tappet solid will actually outperform the roller.
