http://www.compperformancegroupstor...PROD&Product_Code=8920-16&Category_Code=HEHRL
Retro-fit roller cam
Retro-fit lifters w/dog bones
prob new push rods
if you keep the stock shaft mounted rockers then you want solid pushrods. your rocker oiling system wont change. even if you went to magnum heads, only difference is oil through rods and lifters. i want to say just retrofit roller lifters, roller cam, and solid pushrods should get you where you want to be.
i just bought a hughes engines roller cam and retrofit roller lifters. was like 800$ for everything. but after replacing a tappet cam twice now due to wiping, definitely worth the money
Not sure but it sounds like not.
You shouldn't have to, not to say that doing some mods wouldn't be beneficial.Has anyone had to modify the LA oiling system when installing a hydraulic roller?
Be careful with this.... if you put in grooved cam bearings to provide continuous flow to the heads, then an added restrictor somewhere becomes a possibly/probably needed oil flow control device. But if you keep the standard cam 'interruptor' system, then oil flow to the heads will tend to decrease with high RPM's; the oil just can't start and stop well enough with the shorter and shorter flow times through the cam and cam bearing holes when they line up momentarily at higher RPM's. If you are running rockers that require positive oiling (like adjustables), then adding restrictors on top of the standard LA rocker oiling system may starve them if you spend a lot of time at high RPM's. You have to have some pressure up there to make the 'squirters' squirt oil at the pushrod cups, etc.Then you can block off some flow where oil travels from mains to the heads keeping more oil at the mains and rod bearings.
On a factory small block LA dodge it sure does. Oil goes from galley, down to mains and up to cam and out to heads (rocker shafts). On a factory LA oiling system the last part to see oil is the rockers. I did drill out the passages to 5/16" from the galley to the mains, and several other mods to keep oil at the crank bearings.Oil to the heads doesn't come from the mains. If you want more oil to the mains drill the passages from the passengers side oil galley to the mains to 5/16".
Yes you are correct, I don't know where my head was. I apologize if my reply caused any confusion.
Unless you have two large groove on the camshaft instead of the factory timed oiling there is very little loss of oil to the crankshaft. In addition to drilling the ports from the passengers side oil passage to the mains, bushing the lifter bores on the passengers side will help control the leak around the lifters increasing oil available to the main bearings and rods.
I'll be running the same cam in the wife's roller block 360 with only the oil holes from the deck down opened up a bit.Has anyone had to modify the LA oiling system when installing a hydraulic roller?
You could mock it up with your OE rockers and if it looks like it will work good then get the HD rockers.Would these make a difference? Mancini Racing Steel Rocker Arm Set, 1.5 Ratio
Once I get the cam key fitted in to my liking, I'll proceed with the mock up. Take a few pictures and post them up.
Crane coated steel gear is what i use with the billet roller cams. They work great. You can also order your roller cam on a cast iron core and just use a regular gear.
