69MOPE
What is the minimum compressed valve spring spec for use with roller lifters? I want to run a roller on the street but want the lifters to last. .600" lift , max 7000 RPM
My Solid Roller has .634 Lift 242@.050, Spring Pressures are around 160lbs Closed and 510lbs open.
That spring seems a bit light for the lift???? I run a .636 lift with 278 / 286 of duration @ 0.05 and the cam manufacturer wants a minimum of 230-240 seat with 650 open. I actually run about 285 seat and 660 open.
I run a Lunati solid roller and when I called their tech the fellow told me not to go by what was on the cam card. He described the spring pressure data on the card as the bare bones minimum but they would actually like to see more pressure. My card showed 210 and 556 pounds at 1.95" installed height but the tech people said that they actually want a minumum of 230 and 650... Personally I think they should put the range on the cards if that's the case. I bet a lot of people go by that data and run springs a bit lower in pressure thinking the card info gives the ideal pressures.
