Roller lifters
D-mailman
Lexington,ky.
Who makes good roller lifters ? What are you using in your engines. Will be street / strip use.
Thanks
D-mailman
Morrel solid rollers, this set for 2 years on the street turning 6500 rpm. They already had the lifter body design that now hughes,lunati, mrl have barrowed and advertise as working with certain blocks that have the lifter bores counter sunk cut too far. For years most other designs were dumbbell and bleed off too much oil and have no oiling to the rollers, morrels have none of those problems.
Thanks
D-mailman
Buy the highest quality roller lifters you can find. Expect to spend over $1k on solid rollers, and then send them in to have them inspected annually. They should be fine on the street as long as you don't have too high of spring pressure.
I purchased but have not yet gotten to MRL solid roller lifters. I have read many good things about them on various Mopar sites.
Well under a grand!
