TrailBeast
AKA Mopars4us on Youtube
Actually, my guess would be not that your timing changed, but that the improved combustion from the HEI upgrade probably increased the strength of the combustion pressure wave, which increases peak cylinder pressure. Too high a peak cylinder pressure and you get detonation, i.e., ping. So you might need to dial in a couple degrees less advance.....
Not using the vac advance ended up giving me the total that works perfectly.
