Rough idle... only when warm.
Mopar Performance Issues
  1. Jonathan Bass
    Jonathan Bass Member
    8
    0
    Jan 3, 2021
    Washington
    Local Time:
    3:21 AM
    Been trying to get ideas on what people think this issue could be. I'm lost at this point.
    When cold. Car idles, shifts from park smooth, and runs well.
    When warm. Idles rough, engine shaking, shifts from park hard, performance loss.
    I don't understand what would cause that difference other than the choke. Which seems to be adjusted and working properly. Anyone have ideas other than that?
    No amount of timing or idle / fuel mixture adjustment while car is warm fixes the issue.
    Changing from manifold to ported vacuum changes nothing either.
    I sprayed around for more vacuum. Found nothing. Reseated the intake manifold and carburetor. Made sure the throttle blades were closed properly in carburetor. Replaced hosing. Readjusted mixture and idle. Switched from manifold to ported vacuum and retimed. Issue still persists ONLY WHEN WARM.
    I read on a classic Mustang forum somewhere that someone was having a similar issue and replaced their PCV valve and that fixed it. I ordered a new one, so I'll test that when I can.
    But otherwise. Does anybody have any ideas? I'm frustrated.
  2. Joey4speed
    Joey4speed FABO Gold Member FABO Gold Member
    1,300
    985
    Jul 17, 2018
    Coastal NC
    Local Time:
    6:21 AM
    Sounds like you covered all things vacuum.
    What year, make, engine?
    Curious, If you simply place your hand over the carb when its warm, as to choke it, does the idle improve?
    Joe
    • Like Like x 1
    • Professor Fate
      Professor Fate Push the button, Max...
      1,658
      2149
      Jan 13, 2020
      Wisconsin
      Local Time:
      5:21 AM
      Vacuum line should be disconnected from the advance cannister and hose plugged when setting timing.
      • Agree Agree x 1
      • Tooljunkie
        Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
        18,208
        19069
        Jul 22, 2017
        Manitoba
        Local Time:
        5:21 AM
        Details man! power brakes? Slant 6 or a hemi? Somewhere in between?
        power brakes my have a booster leaking vacuum.
        Had a dirty carb, would run not bad until it warmed up,choke would come off and it would get rough. Pulled carb and cleaned it. Solved!
        Plugs burning clean?
        What do you have for a carb?
        • Agree Agree x 2
        • Jonathan Bass
          8
          0
          Jan 3, 2021
          Washington
          Local Time:
          3:21 AM
          361/727. Power brakes yes, but I disconnected the brakes to eliminate that issue. Pretty much brand new Edelbrock 1411, I got it about 3-4 months ago. Choking the carburetor does not improve idle.
        • Jonathan Bass
          8
          0
          Jan 3, 2021
          Washington
          Local Time:
          3:21 AM
          The thing that confuses me most is. Why would the transmission shift from park harder at lower RPM when I'm having warm rough idle, than it would at a cold start with higher fast idle RPM?
          Shifts smooth first start up of day. Shifts hard when warm.
        • Tooljunkie
          18,208
          19069
          Jul 22, 2017
          Manitoba
          Local Time:
          5:21 AM
          Motor mount. Trans mount. Cable shifter? Cable routed too close to exhaust. Been there...
        • Joey4speed
          1,300
          985
          Jul 17, 2018
          Coastal NC
          Local Time:
          6:21 AM
          Jonathan,
          After installing a brand new Edelbrock last year. I had an
          Intermittent backfire and ran hot, thought it was timing or a secondary ignition problem. Tried everything with no luck.
          A wise ole mechanic said the carb was no good, he "didnt care if it was new".
          Had it rebuilt, never ran better, smoother, cooler and stronger. Guessing it had an internal Lean issue.
          Who knew?
        • dano
          dano Evil Handy Man
          3,737
          1597
          Aug 22, 2005
          Gresham, Oregon
          Local Time:
          3:21 AM
          Is the fuel boiling in the bowls? Did you put a heat isolator between the engine and carburetor? Have you verified the float level and fuel pressure?
        • pishta
          pishta I know I'm right....
          19,810
          9183
          Oct 13, 2004
          Tustin, CA
          Local Time:
          3:21 AM
          Carterbrocks run hot. Use a phenolic/plastic/wood or that 1/4 fiber gasket between the intake an the carb. when choked it changes the fuel circuit. Kinda sounds like your float level may be very low. Choked creates alot more vacuum so it pulls more fuel, if your float level is low, your fuel pressure to the boosters is going to be lower and its gonna run lean. When i starts to run like crap, shut it down and pull the top of the carb off as fast as you can to see what the fuel level is.
          • Agree Agree x 1
          • Jonathan Bass
            8
            0
            Jan 3, 2021
            Washington
            Local Time:
            3:21 AM
            I do not have a carb spacer... just a gasket and adapter plate. I can get a spacer and heat insulator gasket and see what that does.
          • Jonathan Bass
            8
            0
            Jan 3, 2021
            Washington
            Local Time:
            3:21 AM
            If I give it VERY light throttle with foot on brake while in drive, the rough shaking idle will smooth out... would that be an indication of anything? Increasing idle speed does not achieve same affect.
          • Kendog 170
            Kendog 170 Let the boy go !
            2,128
            1470
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            6:21 AM
            Definitly get the insulated gasket even if this isn't your issue. You have to have one on an Eddy carb.
          • halifaxhops
            halifaxhops It's going to get stupid around here! FABO Gold Member
            65,722
            35286
            Jan 20, 2014
            Hoppyworld
            Local Time:
            6:21 AM
            What ignition you have? Also does it get progressively worse as it warms up?
            • Like Like x 1
            • mbaird
              mbaird mbaird
              6,962
              3734
              Dec 10, 2005
              boise, Id
              Local Time:
              4:21 AM
              My brother had a similar problem on his Firebird . Turned out to be the fuel pump. When hot it couldnt keep up .
              Worth checking fuel pressure cold and hot ....
            • Jonathan Bass
              8
              0
              Jan 3, 2021
              Washington
              Local Time:
              3:21 AM
              Trying the spacer and gasket today.
              I have a new MSD Blaster coil, new ballast resistor on firewall, new voltage regulator, and original distributor that it had when I bought the car.
              Problem existed with previous coil, ballast, and regulator.
              Will check fuel pressure.
            • swedefish
              swedefish Well-Known Member
              1,826
              146
              Oct 24, 2006
              Sweden
              Local Time:
              5:21 AM
              Step up springs in carb?
            • TrailBeast
              TrailBeast AKA Mopars4us on Youtube
              21,672
              9474
              Mar 11, 2011
              Arizona
              Local Time:
              3:21 AM
              Cold fluid flows slower than hot fluid. (soft shifts when cold) and trying to compensate with idle speed because of a rough running motor can cause harsh shifts, so for now just deal with the running quality and the shift engagement issue will probably go away.
              Sounds to me like the carb is going lean when the choke comes off as it warms up.
              As mentioned above once its warmed up and running crappy try using your hand to cover part of the top of the carb to restrict the air going in.
              If it runs better as you restrict it tells you it’s lean.
              It also works to point out a rich condition, as the restriction causes the motor to run worse.
            • pishta
              19,810
              9183
              Oct 13, 2004
              Tustin, CA
              Local Time:
              3:21 AM
              • Agree Agree x 1
              • Jonathan Bass
                8
                0
                Jan 3, 2021
                Washington
                Local Time:
                3:21 AM
                Also yes it progressively gets worse and worse as I continue driving.
                It hasn't shut off yet.
              • halifaxhops
                65,722
                35286
                Jan 20, 2014
                Hoppyworld
                Local Time:
                6:21 AM
                OK what ignition? Points, electronic, what make etc. Can be a component on its way out.
                • Agree Agree x 1
                • Jonathan Bass
                  8
                  0
                  Jan 3, 2021
                  Washington
                  Local Time:
                  3:21 AM
                  MSD Blaster 2. Brand new. Same issue with last coil. New ballast, new voltage regulator. Only thing stock is distributor. Going to replace that soon. Upgrading to electronic.
                • halifaxhops
                  65,722
                  35286
                  Jan 20, 2014
                  Hoppyworld
                  Local Time:
                  6:21 AM
                  OK if it is points prob a condenser on its way out and if it is electronic can be a pickup in it. You have to be more specific so we can help.
                • AJ/FormS
                  AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                  20,750
                  8136
                  Jan 19, 2014
                  South-Central Manitoba,Canada, 900ftelevation
                  Local Time:
                  5:21 AM
                  what's yur Idle timing?
                • Bewy
                  Bewy Well-Known Member
                  508
                  273
                  Jan 1, 2021
                  Australia
                  Local Time:
                  8:21 PM
                  Could be a few things:
                  [1] Lifter preload [ bottomed out ]. Unlikely but possible. As the engine heats up & parts expand, bottomed out lifters have nowhere to go & stop the valves from seating.
                  [2] Carb. Remove it & disassemble. Unlike brand H & clones, you won't need gaskets if you are careful. Blow out passages with compressed air. In the primary clusters, you will see a thick & thin brass tube hanging out the bottom. The pinched lower end of the thin tube is the idle fuel feed. Poke a piece of wire in it to make sure it is not blocked. Be careful, the boosters have a L & R, not interchangeable. Re-assemble with 7/16" float setting. Set idle mixture screws 2.5-3 turns out from seated.
                  With the carb back on the car, loosen the tops [ 2 turns on the screws ] on the metering rod pistons. Swivel the tops slightly so you can see the piston but it remains captured. Tighten screws.
                  Warm up engine & adjust mixture screws [ in gear if auto ] for smoothest/highest idle speed. Look at the pistons; they should be down & not moving. If they are moving, you need softer step up springs. If they are moving, use a thin screw driver or wire to push the pistons down. If the engine note changes, it means the pri throttle blades are open too far at idle. This can be caused by a big cam, worn cam, PCV that is oscillating & not closing [ usually caused by low vacuum from big cam ].
                  • Like Like x 1
