Running Caltracs with XHD springs?
pettybludart
Ontario,Canada
I spoke with Calvert Caltracs about running with XHD springs(already have them on the car)they said I could.Has anybody used the XHD springs on their car with these?I also have my original 6 cyl springs(kinda flat)and am worried about my big tires bottoming out using these.Any insight is appreaciated,before I make the call
if you run your bars tight, they seem to limit the rear end travel. so bottoming out with the 6 cyl springs shouldn't be a issue. worst thing you can do is try a combination, if it doesn't work try another one...
Thanks 68 HEMI GTS,I,m gonna try the XHD first clamped front and back(as told by Calvert)and if they don,t workout I,ll go to the 6 cyl springs.Thanks for your insight.Happy Moparing!:cheers:
