For you all that run the Trickflow 240s, what rocker arms are you running with them? my combo will be using a comp Cams XE285HL, .545/.545 lift, duration @ .050 .241/.247, lobe separation 110° with a 106° centerline with 10.5:1 compression at a deck height of 0.0. I'm wanting to run a 1.6 ratio rocker but not sure if that'll cause any issues with the trick flows. I also noticed that they offer the 240s with two different spring sizes, which would you all recommend.
