jpeshelman
$250 Shipped
*These were original steel, not coated...never been put on a car, they had surface rust on them......I cleaned them up and painted them high temp silver header paint.
The DD2 header set is designed to fit big block Chrysler (383-440) V8 engines in 1932-Up cars and pickup chassis that do not have a cross member directly under the center of the engine. The DD2 also fits some RVs and musclecars.
The DD2 is a perfect fit for Chrysler "B" and "C" chassis.
Comes with all hardware necessary for installation.
SPECIFICATIONS:
Engine : Big Block Chrysler 383-440 V8
Primary Tube Diameter : 1-7/8"
Collector Diameter : 3"
Weight : 16 LBS / 7.26 KGS
FEATURES:
SPECIFICATIONS:
FEATURES:
- 16-Gauge Primary and Collector Tube Thickness
- 3/8" Thick Flange
- Patented Flange Design Requires NO Gaskets
- Tightest Fitting Header Available Anywhere!
- Made in the USA
