Would the xe274 have more power than voodoo!If it does I'll give it try,I know its a chevy cam lobe!I want to keep more torque but it should sound little more choppy!
This is the intresting thng about cams and the power they make.
What is more power? More torque, more HP? How about where it comes in, how the curve is?
The thing you should know about cams and there specs is what works in one engine will not work in another engine built the same. Alot has to do with the target of the builder and the owner of the engine not to mention what car it is going into...and for what performance arena?
What works for you will not work for another.
To simply say, max HP is an invite to more camshaft choices and bigger ones at that. Nevermind the custom grind choices.
