[WANTED] SB Four Barrel Linkage
540slant6
Mopar SB Ripper
Berryville, VA
Alright Gents,
I'm in search of a full set of kick down linkage for a 72 Duster with a four barrel Eddy and a stock 904 trans. Currently has an aluminum Eddy performer intake. I need the bell crank and everything.
Thanks
Nick
Look at a cable usually better and cheaper.
yep, OEM linkage doesn't work with aftermarket intake and carbs without adapters and/or mods anyway.
Many of those who drop a LA in where a slant 6 was had to change the throttle cable too.
Good luck with it.
I've heard mixed reviews of the Lokar setup which is why I was going OEM. I'm terrified that I may not have it adjusted properly and smoke my new trans.
Thanks for the input fellas.
Same thing can happen with OEM throttle pressure/kickdown linkage. Correct adjustment setup is required with any.
