360duster
Hi Guys,
as most of you know the Heads / Valvetrain are oiled trough timed passages in the camshaft, so there is no continous oil flow. I saw pictures of cams where a groove is grinded around the two journals with the passages to improve oil flow, to make it more continous.
I´m able to machine such a groove (maybe .1" deep and wide?) into the cam journals at work with a grinding machine. Did somebody do this mod, is it a good or bad idea? If there are mopar SB cams out there with this grooves how deep / wide are these grooves? cam from wich supplier?
Thanks for input!
Michael
Thanks for input!
Michael
