madmax2
I want to make a MPFI intake manifold for my 418 stroker.
Currently my combo is a 418 stroker, 10:1 cr,
Edelbrock Heads home ported (280cfm int 196cfm exh @.550")
Lunati solid flat 401A1LUN 270º adv, 243º@050, .548" lift, 110º/104º
weiand xCelerator intake,
Holley HP ecu with Terminator TBI 900cfm,
sequential ignition with eight IGN-1A coils.
The car is a 1970 Dodge early a-body,
6-speed manual from a Challenger 2009 and 3.90:1 rear end.
The car and engine run very well, it responds well at all speeds. I haven't taken it to a dynamometer, but it's a great kick in the pants on the street.
Since the Holley HP EFI supports 8 injectors in sequential mode, I wanted to get an EFI intake and rewire the injectors and buy a 90mm TB
The Weiand Xcelerator seems very good for street use, but they're hard to find used I don't want to modify it to solder the bungs. It has a power band of 1500-7000 rpm.
From what I saw, the other single planes start at 2500, 3000 and 3500 rpm (M1, Victor 340, Strip Dominator and Super Victor)
The easiest thing would be to use a Super Victor EFI but the power band is 3500-8000, but since my car is for having fun on the street I wouldn't want to lose torque at <3000 rpm.
On the other hand, there is the option of using a base from a Tunnel Ram to modify it and use or make something similar to the Holley Hi-ram.
The question is: What would you do, modify a single plane (which one) or a tunnel ram (which one) or would you use the Super Victor directly?
