[SOLD] SBM Turbo Kit
subcom
South Florida
Selling my old Turbo setup. This was built for my Early A, so should fit most anything since the Early A's are so narrow in the engine bay. If you are thinking of turboing your small block, this kit will get you miles ahead. All of the hard work is done. My full build thread is here: Ebay GT45 + 5.9 Magnum + E85 blow thru
-2.5" Mild steel hotside, stainless flex coupler.
-Large 2" Magnum exhaust manifolds
-60mm Wastegate
-Fuel pump block off plate with turbo oil return AN fitting.
-GT45 Turbo
-Procharger low profile carb hat with 1/2" spacer.
-4" Downpipe stub.
-VHT high-temp primer and paint.
$850 shipped to lower 48. PayPal only please. Thanks!
