[SOLD] SBP Front Disc Brakes (complete) bolt in
plumkrazee70
Medford, Oregon
I have a set of front disc brakes that will bolt into any Mopar A body with small bolt pattern. Not sure on the early A's.
What you see is what you get. The control arms are new, pads are new, hoses are new and the calipers are new. The rotors have been turned once. All you need is a SBP upper control arm and this is a bolt in assembly. These clear 14" rally Wheels.
$450 shipped to the lower 48.
So please excuse my ignorance,
I have a 69 dart with drums all around
Small 4" bolt pattern rallyes.
I need different a arms?
For this to work..
Thank you
Mike
For this to work..
Thank you
Mike
No problem. You don't need new arms. You keep your upper and lower arms as is. All you would do is unbolt your spindle from the upper and lower control arm and bolt this on. Attach brake lines and bleed brakes.
The kit shown is just all put together, to make it easier on the buyer.
The spindles and lower ball joint are identical to what you have now.
Ok thank you.
P.m. sent
