SBP Hubs question
Kendog 170
Let the boy go !
Reading Ma.
Are the hubs all different on 68-72 A-bodies? KH, 9" and 10" drums? I think a race spun in my KH hub (haven't disassembled yet) and was curious to know. TIA.
Anyone?
The 10" drums use the same bearings and 5 on 4" diameter hubs. Measure both with a tape measure for certainty
Do no think that works from when i swapped but its been awhile
The hubs, or just the bearings?
Hubs. Will 10"drum hub fit KH ? They are harder to come by and I do have 10" drum hubs packed away somewhere.
I was just asking @junkyardhero for clarification on that.
Let me rephrase. Has anyone used a 10" drum hub on a Keysey Hayes rotor?
Looks like the answer is no.
my apologies for the cornfusion. i thought we was talking about bearings.
no, i don't believe that the drum and disc hub interchange. i have a drum hub on the bench and a disc w/ hub on the shelf, i'll check it later today but my assumption is that they are completely different.
they 100% use the same bearing and seals, but i'll wager a guess that the "heights" are completely different.
10" drum and KH disc hubs are different (and don't interchange) although the bearings and seals are the same. 9" drum are different still and use different bearings and seals.
