Scat stroker crank, mopar woodruff key...Too Short :/
MP is nont what it used to be. You can get that same key at a good local hardware store - probably for less $$. I think it's fine unless you're driving a blower off the balancer. You can get Mr. Gasket ones that overhang the groove a little - but once the balancer is on it's a press fit and unless there's a big draw off the pulley(s) I can't see it slipping or shearing that hardened key.
