Red_Duster
I've got that cam in a 9.5 440, timing is set at 16 at idle, 750 rpm, and 39 degrees total. This is with 452 heads that have been pocket ported with 2.14/1.81 valves. The combination made 520 hp 545 tq on pump gas with a old M1 single plane and Holley 850.
It sounds like you don't have enough curve in the distributor, I would like to see a 22° sweep with a total of 38 or 39° all in by 2500 rpm at the latest.
I am going to ask at what rpm the converter flash at and what does it stall at?
I whould replace carb with a Holley style race carb with 4 corner adjustment to help with the idle.
I would replace the carb before you replace the torqconverter.
Still learning, so this may be a dumb statement... but to check the flash I need go WOT in 3rd from a slow roll, right? and I can check stall the foot brake way? The converter was pretty high on my priority list because it also has two adjacent teeth missing that occasionally land on the starter.
