seat belt removal
zartan
albany
i'm sure this has been asked 100 times before but what tool do i need to remove the seat belt from my 72 swinger?
Depends on year model so all answers above are correct, either a 13/16 socket or T50 torx driver
i picked up a torx driver i'm going to give it a shot tomorrow
ok having some issues with this as well i turn the bolt on both sides and they just turn and turn and turn.......but there still tight anyone else have this problem
If you're talking about those near the doors.. That nut is/was welded in the inner structure. You might have some rust issues in there. I would cut the head off the bolt I guess, then dig on in. Hope for the best and be prepared for the worst. Good luck
