72dart_swinger
- Joined
- Oct 2, 2009
- Messages
- 438
- Reaction score
- 7
I was thinking of adding a second fuse box for small accessories such as a tach, lights in a 3 gauge pod, and (maybe but not likely an electric fuel pump sometime in the future). I want all of these to turn on and off with the key. What is the best way to do this. Also I noticed that the fuse box has a blank spot in it. The hot side has a spot that has a male connector where another wire can be tied in, and there is no fuse holder on the "cold" side. Would I be able to run a wire from this blank spot to a small fuse block/box for low power accessories or would that be too much current flowing through the ignition switch?
