Bump steer the second
roaddevil
Could it be, that i mounted my spindles the wrong way and the brake caliper belongs in front of the spindle and i have the left spindle on the right and the right on the left and this ist causing my steering problems ? if it is even possible to mount em the wrong way ?
Don't know about your original question, but it does appear that your calipers are installed on the wrong side(s). The hose should be at the bottom, and the bleeder should be at the top, otherwise you're gonna have a helluva time getting all of the air out of there.
I use the factory 73 -76 a-body spindles with no issue either side mount the the calipers front or back. We put an after market set on the barracuda and it has bump steer pretty bad. He is now looking for factory spindles to replace the aftermarket.
Many, MANY of us have used EG 73/4 Duster/ etc spindles reversed side to side with no issues.
You really should not start a new thread. We can't remember what "all." How about wheel offset?
You keep calling this bump steer, but maybe that is not what is going on.
i think you use 69 camaro rubber brake lines if you mount calipers on the rear. they are longer. dr diff sells them.
your caliper bleeders are supposed to be at the top of caliper. switch sides with your calipers. buy new brake lines and re-bleed your brakes
