On a Edelbrock carb, looking at the front of it, hook the distributors vacuum advance hose to the lower right nipple directly from the distributor. The black box is a delay box for emission reasons. IIRC, it delays spark advance by 15 seconds.
To check if the secondaries are opening all the way, with a friend and the engine NOT RUNNING, have your buddy depress the gas pedal to the floor. You will look down the carbs secondary side and open the secondary sides air velocity flap, the counter weighted door. A pencils eraser is a good help.
The AFB's are a mechanical operating secondary all the time with the counter weighted air door above it that opens upon demand of more air flow.
Should the pedal NOT open the secondaries all the way, adjust how the throttle cable sits in the clamp on the manifold. Move it rearwards towards the fire wall.
If your wondering if it opens all the way when your driving, it does so long as the above is working properly.
