So i ordered a limiter plate from don at fbo, the plate arrived and i pulled the distributer out of my 360 taking pictures of where the rotor was sitting at. I pulled the distributer just to find out that the distributer i have had all along is the newer mopar distributer that has the mallory guts in it with adjustable mechanical advance, so i got the mechanical advance set at 22 degrees running an initial of 12 degrees with 34 total and it ran good but of course the springs that came with the limiter plate do not fit the newer mopar distributers so my advance was coming way to soon around 2000 rpm this is in a four wheel drive truck mind you. So i had 3 or 4 older style mopar distributers i threw ne together with springs that will make it all cme in around 3000 rpm according to dons sheets. I take my newer mopar distributer out drop in the one i put together go to start it up and its not running right so i thought maybe the gap is set wrong on the pick up coil or something and figured i'd mess with it later. I put my other (newer mopar distributer) back in and go to start it and now it wont even start and its kicking air out the carburetor...... what the hell is going on here? obviousl i have the distributer sitting in wrong or something and how in the world do i correct this mess up? i hope is fairly easy i am so sic and tired of nothing going together and working good for me on this dam engine.
