Roadart
I am using nasson epoxy and activator. Do you mix 1to 1? After mixing should you let it sit(above 70degrees,30 minutes,below 70 degrees sit 1 hour)? apply second coat of top coat primer within 24 hours? (never heard that before) First time doing this SO bear with me.Any helpful hints are WELCOME.
