Sfi Flexplate Recommendation
A/MP
360 internally balanced, 6 bolt crank, 8" converter, 904 trans about 550HP. I'm looking for a flexplate for this combo. A Mopar performance flexplate cracked at the bolt hole. I was thinking to use a B&M round unit but I would have to remove the counterweight for an externally balanced flexplate and this would void the sfi. Any suggestions?
The TCI part#145200 is listed to fit 6 bolt crank internally balanced Mopars with either a 904 or 727 trans. and it's SFI 29.1 rated. Only thing I'm not sure about is the converter bolt pattern since your running a little 8" converter but it does say it is drilled for 7/16" converter bolts so it should fit.
