Snake
Mopar Nut
Do any of you grease the rubber shackle bushings befor you slide them in.
i noticed some galling on my old rubber bushings so i gave the new ones a light coat of silicone grease i had around. (for o-rings on pool equipment)
No, I use gaskacinch to glue them in place for the OD, so the far one doesn't walk out while I push the stud through it. Then grease or use penetrating oil on ID of the bushing or OD of the shaft before pushing it through to help keep from pushing the opposite bushing out...
Thanks for all you thoughts,a little tad of grease it will be.I kind of figured grease would be helpfull,it sure would of been 4 weeks ago, I had 1 L side shackle flip, when i took it a part the studs were frozen on the rubber sized .Remember that pic.It would not let it go all the way back.
Use a pry bar to help put the shackle in the proper position while it is unsprung, then lower the car and as the spring lengthens under load, it should go back to "normal" position.
that happened to me once...
