They are a Got-To-Have without AC. My convertible has the vents and I use them often but it doesn't have Air Conditioning.I don't mind the "new" look but I'll tell ya............there is no WAY I'd give up cowl vents. I think ALL cars should have 'em
Well, You are certainly entitled to your opinion, so tell me why is it so important to have them? Especially when they won't be used and are not needed.
My question, can the electronically controlled A/C setup be controlled using a double din touch screen head unit? I'm looking at a Kenwood unit that when used in new cars, has the ability to control the climate controls. Something I'll have to check into once the time comes.They are a Got-To-Have without AC. My convertible has the vents and I use them often but it doesn't have Air Conditioning.
But... I don't think I will miss them in this car.
The Classic Auto Air AC/Heat system I'm installing in the fastback only uses recirculated cabin air and blocks off the cowl opening inside the car eliminating the outside air.
Don't need 'em anymore and like the clean look without the grate in the cowl.
Frosty Cool Air on demand? Yep!
Defrost, Floor and Dash outlets? Yep!
Infinite Floor/Dash Blend? Yep!
Outside Air? Guess I'll have to crack a Wing window or roll one down. It's all good.
Can you post the model number of the Kenwood? Also thinking of putting a double Din in place where the old heater controls were and the AC/Heat controls where the radio would go but if I could control it from the touch screen I might delete the Classic Auto Air controls.My question, can the electronically controlled A/C setup be controlled using a double din touch screen head unit? I'm looking at a Kenwood unit that when used in new cars, has the ability to control the climate controls. Something I'll have to check into once the time comes.
I'm not sure exactly which model I'd do yet. I'd like one with backup camera and possibly front camera since the car will be low and I may do a custom front air dam, then I could see curbs when pulling into a parking spot. Also want one with navigation so it'd probably be something similar to the DNX693S.Can you post the model number of the Kenwood? Also thinking of putting a double Din in place where the old heater controls were and the AC/Heat controls where the radio would go but if I could control it from the touch screen I might delete the Classic Auto Air controls.
Have a Kenwood DNX5120 in my truck but with smart phones today that will directly interface with most new head units I will not be getting Nav in the deck... adds at least $100 to the cost. I do like the garmin in my Kenwood but Google maps works really well.I'm not sure exactly which model I'd do yet. I'd like one with backup camera and possibly front camera since the car will be low and I may do a custom front air dam, then I could see curbs when pulling into a parking spot. Also want one with navigation so it'd probably be something similar to the DNX693S.
The price will be a little hard to swallow but if I can get all the features that I want to work I think it'd be worth it.
https://www.google.com/search?q=kenwood+dnx693s&ie=UTF-8&oe=UTF-8&hl=en&client=safari
Ok I was going over the features of the DNX693S and couldn't find anything about it working with climate controls but I did see that the DNX573S can be adapted to work cars that have a touch screen climate control (like our 2016 Chrysler 200)
Well piss.My memory from when I researched this was not possible to do unless you have the computer from the car that the AC system is from
My favorite quote, "back in the day". When I was a kid, a long, long time ago, there were no cowl vents. You rolled the window down and let the wind blow. In the late 40's, 50's and 60's we got vent windows. Same story though let the wind blow. Peyote, I'm with you.
You mean like my 72 Duster? LolThis another thing I detest...........modern cars without vent windows.
